i am trying to implement a .NET DLL compiled in MATLAB within an Addin-Module created with the .NET API Wizard in Visual Studio 2010. When a function from the MATLAB DLL is called, this error occurs in the console:
An Error has occurred while trying to initialize the MATLAB Runtime.
The error is: Fatal error loading library C:\Program Files\MATLAB\MATLAB Runtime\v910\bin\win64\libmat.dll Error: The specified procedure was not found.
MATLAB DLL:
- system architecture: AnyCPU (64-bit preferred)
- runtime environment: .NET Framework 4
.NET API Addin DLL:
- system architecture: x64
Application versions:
Creo Elements/Direct Modeling 20.1.4.0
Visual Studio 2010
MATLAB Runtime: 9.10
MATLAB 2021a
Is this procedure possible, if yes what can I do.
You cannot just load a DLL into SolidDesigner.
The only accepted DLLs are compiled LISP sources.
For that you need a SolidDesigner IKIT Licenses.
When you try to load your DLL, SolidDesigner is looking for a an initializer function expected by the LISP System.
Thank you for your reply.
I try to make some things clear.
I do not use the Integration Kit. I am working with the Creo Elements/Direct Modeling 18.0 - COM & .NET API, which allows .NET-based clients to be loaded into Creo Elements/Direct Modeling process (.NET add-ins). I used the provided wizard for Visual Studio 2010 to create a C# program and compiled it into a DLL. The add-in consists of this DLL and an additional configuration file. If these two files are placed in a specific folder, the add-in can be loaded into Creo Elements/Direct Modeling using File > Modules. It is also possible to call another .NET DLL (created with VS2010) within the add-in DLL. When calling the .NET DLL (created with MATLAB) within the add-in DLL, the above error shows up in the console.
