hello, I was using PE yesterday fine and when I turned it on today I got the modeling screen but very little else. I was looking at the forums, and turned on the verbose version and got the below error in the command prompt, I then tried restart and then reinstall with no luck. I looked (only looked) in the registry and could not find the ""clsid\{...}"" info either. can anyone help? Command window: Loading C:/Documents and Settings/Dan Kilduff/Application Data/CoCreate/Modeling PE/20.00/sd_data.lsp Finished loading C:/Documents and Settings/Dan Kilduff/Application Data/CoCreate /Modeling PE/20.00/sd_data.lsp Loading C:/Documents and Settings/Dan Kilduff/Application Data/CoCreate/Modeling PE/20.00/all_data.lsp 20.0.0.34 04/11/09 19:01:39 - CLSID\{D554F11D-87A2-4145-B6BA-E5219F131092}\: ERR OR - Cannot find registry entry
