Export to JT
ptc-3191571
Export to JT
I want to export my assembly file to JT format.Conventional method to do this is File->Save a Copy select file type as Jt and click "OK".
Issue I am having is File type as ".jt" is not appearing in that list.I tried setting config option "intf3d_out_jt_brep" to "jt_brep" but still file type didn't appeared in the list.I read somewhere that Jt interface license is also required so I checked setup using ptcsetup.bat and JT Interface was selected to install.
Now plase help me to -
Export ProE WF 5.0 file to .jt
How I can check if I have proper license of JT FX.
0 REPLIES 0
