External merge sketch is purple in color, different from other sketches
getsidgo
2-Explorer
I am using Creo Parametric Release 4.0 and DatecodeM150
I am trying to create a schematic sketch using the external merge feature, and it is appearing purple for some reason. I have other external merge sketches that are the normal blue color, and I can't find a setting to modify this. Please advise how to change this.
3 REPLIES 3
tbraxton
(To:getsidgo)
You should provide more information and post the model or a test case model. Creo entity colors are subject to the settings of UI customizations including system color settings. You refer to a schematic sketch, in Creo this could refer to many things (routed systems, Creo schematic etc.) so you should to clarify this.
Involute Development, LLC
Consulting Engineers
getsidgo
2-Explorer
(To:tbraxton)
Thank you for your reply, here is an image of what I was referring to:
This sketch is a external merge inside the .prt template as shown here:
Hi @getsidgo
Could you share the data or the steps to reproduce if it can be reproduced on a generic data?
Amol Lungare
