I am using Creo Parametric Release 4.0 and DatecodeM150
I am trying to create a schematic sketch using the external merge feature, and it is appearing purple for some reason. I have other external merge sketches that are the normal blue color, and I can't find a setting to modify this. Please advise how to change this.
You should provide more information and post the model or a test case model. Creo entity colors are subject to the settings of UI customizations including system color settings. You refer to a schematic sketch, in Creo this could refer to many things (routed systems, Creo schematic etc.) so you should to clarify this.
Thank you for your reply, here is an image of what I was referring to:
This sketch is a external merge inside the .prt template as shown here:
Hi @getsidgo
Could you share the data or the steps to reproduce if it can be reproduced on a generic data?
Amol Lungare
