I'm using the CREO 3.0 M140 and this error is recurring. Could anyone help me? I'm sending the error log for analysis.thank you
Is this a standard run of Creo or do you have some custom toolkit programs running with Creo?
What are you doing when the crash occurs? Is it repeatable?
A traceback is really only useful by PTC who have the tools to read the file and understand what the error codes mean.
Have you looked in std.out or your trail file and see if they have any useful information?
please report the problem to PTC Support.
I remembered that Creo 3.0 lifecycle was terminated 🙂 Therefore I am not sure what PTC support will tell you.
Last version released is Creo 3.0 M190 ... I suggest you to download, install and try this version.
