Fatal error on part creation while uploading another part
AdrienKLEIN
I am using Creo Parametric Release 7.0 and Datecode7.0.8.0
I experienced something weird with Creo 7.0.8.0 and Windchill 12.0.2.1 :
When I save and upload a CAD, if I am quick enough to create a new part while the upload is running, Creo crashes with a fatal error.
This problem is easily reproducible (only need to be fast).
Any idea what is the cause of this issue? Is there any way to tell Creo and/or Windchill not to start a download (in this case, the startpart) while another server operation is running (in this cas uploading a CAD)
Thank you in advance
The solution to this post can be found here.
Andra
StephenW
(To:AdrienKLEIN)
Seems like you choose the wrong option and posted this back to the community
Yes it seems, my bad...
Andra
