Feature parameter in to assembly repit region table
TP_10167633
11-Garnet
I would like to include a feature parameter in the assembly table.
For instance, in the part named "test," I have a feature called "change." In this feature, I have a parameter named "test."
I would like to include this parameter in the assembly table.
Is it possible to do this?
T.
AndrewK
Community Manager
(To:TP_10167633)
Thank you for your question.
I’d like to recommend bringing more details and context to your initial inquiry. It also helps to have screenshots to better understand what you are trying to do in your process.
Van_AG
(To:TP_10167633)
Table cell text will have format &PARAM_NAME:FID_XXX:YY
where
PARAM_NAME - name of the parameter 'test'
XXX - ID of the feature 'change'
YY - session ID of the component 'test'
To found XXX click RMB on the feature in the assembly tree > Information > Feature Information.
Look for INTERNAL FEATURE ID
To found YY see this help page.
Another way to found both YYY and XX:
Open relations window of the assembly,
Expand 'Local parameters' area,
Set parameters filter by 'Current and all sub features'.
Click RMB on the parameter 'test' and 'insert to relation', you will see both YYY and XX values.
Hi @TP_10167633,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
