I need to find this file inside creo , I've searched and all the PTC folder , but it doesn't find anything pmech_conn.TXT
If you search for this in your browser you will likely get something like this:
It states that the file referenced is created (in your current working directory) in response to some sort of error. Hopefully that is where you will find it. Pro/ENGINEER and now Creo likes to write errors into weird named files like this. Hopefully if you find it you will have some useful information about what is wrong.
