Is there a list of settings one must set to stop the pop-ups that Firefox won't install when opening Creo and/or the detail structure tab? I tried to disable the version checker from being installed but it keeps returning.
Once we upgraded to WC 11.0 and Creo 4 the first Cad object you open with Creo, Creo makes you log into it. That did not used to happen before the upgrade. We are running our WC HTTPS now.
Please Advise
This is intentional by design and will happen with all browsers.
From this article: https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS237817
Out-of-the-box, Windchill 11.0 M010 is configured to use the new Creo View Agent launching mechanism:
Additional information: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS252026
