Firewall LMADMIN
Matteo_1987
Firewall LMADMIN
Goodmorning everyone,
I have installed Creo Parametric to a client on 2 PCs.
It has a floating license and so I have installed the license manager LMADMIN on the server.
When the server's firewall is active Creo is unable to take the license.
What ports and files do I need to enable in the firwall for everything to work?
Is there a document?
Matteo.
@Matteo_1987
By default it needs TCP 7788.
If required you can assign a specific port to vender daemon as well
https://www.ptc.com/en/support/article/CS28776
3 REPLIES 3
@Matteo_1987
Matteo.
there are two options.
1.] define 2 Inbound Rules enabling access for 2 exe-files ... lmadmin.exe and ptc_d.exe
-OR-
2.] define 2 Inbound Rules enabling access for 2 TCP ports ... 7788 and another one
another one TCP port related to ptc_d.exe must be configured manually (see administration guide)
Martin Hanák
Firewall Inbound Rules must be defined on license server, only.
Martin Hanák
