I'm installing CREO 10.0.6.0 to use CREO Anysys Simulation, when I start it gives a flexnet version error, I've tried all possible versions and I can't get it to work, the license is for CREO 11, as shown in the print
The only other thing I've found (copied from CS413906 referenced in my message above) is this info:
This is pretty much all I can figure out about this. If you still can't get things working, the best bet is to contact the people who sold you the licenses and ask them to help. They are usually very good at this kind of thing, since it's the core of their business.
What I see is that you have licenses that are valid for Creo 11, which is good if you're trying to install Creo 10.
What the error messages are telling you is your FlexNet installation on your server is not of a high enough version to be used with the software you are trying to use. You or your network administrator need to update the FlexNet license server to a version that is compatible, apparently at least 11.19.
In olden times, FlexNet licensing was bundled together with the Creo installation, but that's not the case anymore. Someone has to download the most recent FlexNet licensing installation from the PTC site, and replace your installation. Just make sure whatever you download is compatible with ALL the things you intend to use.
I did a quick check and for Creo 10.0.6 the download area tells you:
Creo 10.0.6.0 is packaged with the PTC License Server powered by FlexNet Publisher 11.19.6.1. For VERY IMPORTANT information, refer to CS413906
So if you take care of things to comply with this requirement, you should be okay.
So I went to the PTC website and downloaded this version for flexnet, but I still got the same error, my machine is windows 11
If you run ptcstatus, what do you see?
It's a batch file located in something like "C:\Program Files\Creo 11.0.1\Parametric\bin". It should tell you the version of FLEXnet Publisher your computer is seeing (mine is 11.17).
Here's how it looks
So, the third line says that you're running version 11.17, while the error message says the minimum it requires is 11.19.
FlexNET needs to be updated to 11.19 (and restarted).
I've just done it, now CREO Anysys Simulation isn't working.
