Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
This is a little off topic but I hope you can help,
I have been blessed with a new machine which we eagerly set up yesterday. I use a "spacetraveler" as an extension to my left hand without which I am lost. Somewhere along the way, I lost my config.pro so I borrowed one from another machine. Now when I zoom in and out especially in drawing mode, the screen flickers excessively. Is there something I have lost from my config.pro that would prevent the flickering or is it something that I have failed to download from 3Dconnexion?
BTW returning to my "old" machine, I have the same problem so it is not graphic card related.
