Use CTRL ++ /Ctrl -- for zoom level on the embedded browser.
Mouse scroll doesn't work.
Don't know if anyone saw this but Document CS49015 on PTC's site shows it's fixed in WF4 M230, WF5 M170 and Creo 20.0 M040. Good to knowit's fixed ina build that will not be released for WF4.
Steve Galayda
I submitted a call and they got back to me with a couple of registry entries for using the scroll wheel. On PTC's site it's Document CS46720. These entries allowed the Ctrl+mouse scroll wheel to increase and decrease the size of text in the embedded browser. Positive.
After restarting Pro/E the size went back to the original size: small. Negative.
Not only that but the entries are only for the scroll wheel. The Ctrl+ and Ctrl- still do not work. Negative.
One other incredible thing is I thought the size in the separate browser might control what is seen in the embedded browser. So I changed the text hight in the separate browser, closed the browserandstarted Pro/E. Text size was unchanged. I opened another browser and the text in the separate browser went back to default. Negative.
Steve Galayda
Does anyone have confirmation from PTC that WF4m230 will be issued? It does not show up on their product calendar (M220 is the last one). When speaking with tech support about another issue with Wildfire 4& Windchill 10 their response was to confirm the bug, but say the fix was to move to Wildfire 5 or a release of Creo. The tech said they were no longer working on patches andwould not be issuing updates forWildfire 4 past M220. Oddly,M230 does show up in Update Advisor.
On the font size issue, we have one user out of 40+ that have reported this. We've tried several things including the reg edits and nothing works. We did find he had set his Windows desktop display to show icons with large text, which seemed to be the trigger in his case. Large desktop text = tiny Pro/E embedded browser text. Normal desktop text = normal embedded browser text. No matter what we did, there was no adjusting the size from the browser (scroll wheel etc). I supposed I could try switching it to the 32 bit version if IE.
