Graph color setup
ptc-772172
Graph color setup
Does anyone know how to easily and quickly set up results windows for printing? Specifically, I am referring to graph plots.
I am plotting convergence graphs in Mechanica. The default colors are yellow/green on a either a black or blended background. For printing purposes, I switch to a white background. Unfortunately, the grey gridlines/axes and the yellow text do not show well on the white background. It is a VERY painful process to switch all of the text and lines to black. However, the worst part is when you modify the definition or refresh the screen. ProE resets the colors!
Can the defaults be set somehow in the config.pro or is there a way to set up a mapkey to easily switch the colors?
Alan
0 REPLIES 0
