Hi. I was able to download wildfire 5 and I can run it. The problem is that it goes very slow. Before I go and get a new graphics card, I was wondering if there is some sort of option change I could try? Thanks.
why do you ask the same question a second time ?
It seems that your laptop and Pro/E aren't the best combination.
http://communities.ptc.com/thread/33937
http://communities.ptc.com/thread/33246
Have a look at the requirements for Pro/E. You find them on the PTC homepage.
To answer your question:
Have a look at the Help Center and search for configuration. The desired option is called 'graphics' and there you find diffrent possible values.
What's your laptop name and manufacturer?
