Has anybody found a solution for Exception - code was -1073741819(drw->PDF)
stripathy-2
While saving a drawing as PDF in Wildfire4.0 build code M190, proE crashes with exception-Exception - code was -1073741819. Most discussions in the forum hint about changing the graphics setup in Options( from opengl to win32 or vice-versa) but doesn't help at all.
try to save PDF to local disk to a directory with full access rights. Do not use spaces and special characters in names of directories.
MH
Martin Hanák
