Where should the default directory be located?? Where should the extraction folder be located??? Where should the temp license be located ?? The downloaded software is on my desktop. And after several attempts at using the defaults to install it is still not installed. If you can I would appreciate it.
Please submit your request in "Academic Support Request" form: Academic Case Logger
And find "PTC Creo 3.0 – University Student Standard – Quick Installation Guide" here: http://apps.ptc.com/schools/references/install_creo3_unistudent_standard.pdf
VladimirN:
I have tried what you have attached with no luck, and have had no response from Academic Support. Any other assistance or specific help ??
