Hide cosmetic lines in general view
YT_8243767
2-Explorer
I am using Creo Parametric Release 4.0 and DatecodeM110
Hiding cosmetic lines in the general view also hides cosmetic lines in child detail views
Please tell me how to hide the cosmetic lines in the general view and display them in the detailed view.
Translated the text from Japanese to English using google translate.
Subject - 一般ビューのコスメティック線を非表示
Body: 一般ビューのコスメティック線を非表示にすると、子の詳細図のコスメティック線も非表示になります
一般ビューのコスメティック線を非表示で、詳細図のコスメティック線を表示する方法を教えて下さい。
tbraxton
(To:YT_8243767)
In the part model place the cosmetic items on a layer.
In the drawing top level layer definition, show the layer with the cosmetic items. This would result in the cosmetic items being visible in all views.
Set up a view specific layer definition for the general view to hide the layer of cosmetic items.
Define the layers for the general view in the drawing and hide the layer containing the cosmetic items.
Involute Development, LLC
Consulting Engineers
tbraxton
(To:YT_8243767)
Hello @YT_8243767
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
