Hole redefinition
JWayman
Hole redefinition
Good morning.
I have, once again, just redefined a hole. In this case, I changed a tapped
through hole to a counterbored tapped through hole and changed its primary
reference.
And, once again, Pro/E removed the dimensions I had previously entered in
the secondary references box and assigned apparently random values. I wanted
to use the same secondary references and dimensions. Good thing I could
remember what they were.
On this occasion, I spotted that the hole had moved, but I can imagine a
case when the hole moves only a small distance, not enough to be obvious,
but enough to change a part from correct to no good.
Is there a config option I can change to improve this strange behaviour? Or
do you have a technique that avoids random placement of holes?
In a similar vein, is there a config option that makes it automatically go
to secondary ref collector once I have selected a valid primary ref?
WF2, m220
Can't you edit references rather than redefining the hole?
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
