Host Name having Host ID format showing invalid.
ptcengineer00
Hello
I was trying to move license from one server to another. Using following link.
https://support.ptc.com/apps/licensePortal/auth/ssl/advsearch
My current Host ID and Host Name are same (this is what we have followed)
1
Now in the link, I am unable to add Host Name as xx-xx-xx-xx-xx etc.
It is taking alphanumeric without "-" in between whole string.
2
Is it ok to have Host Name different from Host ID?
Thanks in advance
00-ZZ-AA-AA-AA-AA is not valid HOST-ID. All characters must be hexadecimal digits (0 to F). Hostname can be arbitrary.
Martin Hanák
After entering valid HOST-ID I tested entering new Hostname. You are right ... control mechanism implemented on web page does not allow to enter HOST-ID followed by text.
It seems to me that following page allows you to set Hostname according your needs.
https://support.ptc.com/apps/licensePortal/auth/ssl/hostManagement
Martin Hanák
Thanks MartinHanak
That  HostID was for illustration.
Thanks for input.
