How create parameters with accentuation using Model Check?
Victor_Brumatto
9-Granite
I am using Creo Parametric Release 10.0 and Datecode10.0.8.0
Here are the errors that I faced
I'd like to create parameters via model check, but it's absolutely essential that the parameters have accents.
Here's an example:
ASM_PARAMETER DENOMINAÇÃO STR EQ PDM
PRT_PARAMETER DENOMINAÇÃO STR EQ PDM
DRW_PARAMETER DENOMINAÇÃO STR EQ PDM
Hi @Victor_Brumatto
I think setting MC_SUPPORT_LEGACY_STRING to Y in config_init.mc should help you.
Reference article https://www.ptc.com/en/support/article/CS210551
Thanks.
Hi @Victor_Brumatto
Thanks.
Tks for help me.
