How to Save the config.pro of Intralink
ptc-2112144
Hi guys, I have created a attribute column in the intralink. when im closing the intrlink and again opening it, the column is not available. Can any one help me out to fix this problem. i need to save the setting of intralink. how? REgards, balaji. M
Dudes, can any one help me out to fix the intralink problem. i have posted this question in Pro-Intralink Forum, but no reply yet... Whether PTC can help me?
Dear balaji, if i am getting right,you are trying to save table configuration for workspace.so that you can get desired table confifuration in next session also. STEP-1 for this you have to select table configuration - create - give a name to configuration - include desired attributes. STEP-2 goto preferences - configuration Tab - select Workspace in Browser - check set table display - select the configuration name what you have created in Step 1 - APPLY - OK
