While modeling, in sketcher mode, the construction line is very difficult to see. I know I can change the individual line (edit line)...but how to change the default setting? I just want to change that line-type only (away from dotted)...or some other font/line-type that can be seen. Several suggestions out there to change settings back to an old wildfire color scheme...I prefer not to do that. Just want to fix this one issue. Thanks.
I've never seen a setting for the construction line font. One of the problems is with the color of the construction line, dim yellow. You don't have to change all the colors, just change the bad one...make sure you save a systems color file and add that file to your config using system_colors_file option.
