how to do purge in creo 2.0? what is the maximum character we can put for a file name in creo 2.0? i am confusing between 31-34
Thank u
Elango,
I did a simple test in Creo Parametric 2.0. Name of the part can have up to 31 characters (no Family Table inside the part).
Examples:
a234567890a234567890a2345678901.prt.1 ... visible in File > Open dialog box
a234567890a234567890a2345678901.prt.11 ... visible in File > Open dialog box
a234567890a234567890a2345678901.prt.111 ... visible in File > Open dialog box
a234567890a234567890a2345678901.prt.1111 ... visible in File > Open dialog box
a234567890a234567890a2345678901.prt.11111 ... visible in File > Open dialog box
a234567890a234567890a2345678901.prt.111111 ... not visible in File > Open dialog box
a234567890a234567890a23456789012.prt.1 ... not visible in File > Open dialog box
Martin Hanak
Elango,
Examples:
Martin Hanak
Elango,
As Martin mentioned in last replay 31 character is the limit of file name, I would like to add some more information about files (from Creo help).
About Creo Parametric Files
Saving an object to disk creates a file with the following format: object_name.object_type.version_number
For example, if you create and then save the part bracket, the filename for the part is bracket.prt.1.
Regarding Purge:
Check existing post Purging in 3.0 , it is applicable for Creo 2.0 as well.
