How to get download of Creo4 M060
Joany
I am using Creo Parametric Release 4.0 and DatecodeM060
Is it possible to get download of Creo 4 M060, which is not available in download list now?
MartinHanak
(To:Joany)
@Joany wrote:
Good to know the file is compatible. Thanks for the info,
a little notice ...
Creo Parametric 4.0 M060 is not 100% compatible with other Mxxx. This is because every Mxxx "contains its own set of bugs".
Note: If your customer does not have a copy of Creo Parametric 4.0 M060 installation media, then simply copy Creo Parametric 4.0 M060 installation directory from customer's computer. That's all ... of course you have to modify parametric.psf to run your license.
Martin Hanák
7 REPLIES 7
remy
(To:Joany)
The oldest datecode available for Creo 4.0 is M140:
Do you have a particular requirement to have the M060 CD?
Joany
(To:remy)
Yes, our customers are still using M060, so we have to set up the environment and verify our solution on it.
remy
(To:Joany)
Right you need to verify your customers files and make sure that he supports yours in turn.
Like @BenLoosli pointed out, the compatibility within a release is guaranteed by PTC so when you open your customer's file with M150 and save it he will be able to resume with M060.
If the contrary happens, then it is against our warrantee and we will do everything to have that resolved.
On the other hand compatibility between releases is guaranteed solely backwards meaning that Creo 5.0 will open Creo 4.0 files for example.
BenLoosli
(To:Joany)
All releases of Creo4 create files that are compatible. M140 and M150 can save files that can be read by M060.
The oldest copy I have is M080.
Joany
(To:BenLoosli)
MartinHanak
(To:Joany)
a little notice ...
Martin Hanák
Joany
(To:MartinHanak)
