How to get past "please exit the already running installer..." error?
SD_10047527
2-Explorer
I'm trying to install the latest version of Creo.  Something happened where things hung on my initial install and now when I try to run the setup app, it gives me the exact same error as is discussed in https://www.ptc.com/en/support/article/CS323172
This article directs me to kill setup.exe, but I don't see that anywhere in my task manager.
I've tried restarting my computer, and the issue persists.
Does anyone have any ideas on what I could do to get past this?  Is there some sort of bread crumb or other setting that I need to clear?
Thank you.
BenLoosli
(To:SD_10047527)
The installer creates a log file that may be preventing you from restarting the installer. It is in your home directory, I think.
Also, did you delete all remnants of the initial Creo install before trying it again.
