I am a single use, so I do the sys. admin, but I'm not really that savy with it. I have received my new license, but I don't have a clue as to how to load them. I've searched high and low on PTC support, and here PTC community to no avail. I've look through the files on my PC and nothing stands out as to how to load license files. I'm running Windows 11.
Please help, I'm dead in the water.
Going back to the reseller was the best way. They knew better than anyone how to install the license. Thanks for the time and effort!
Henry
First, if you have purchased your license from someone, that company is the best place to go for help with installing the software.
Once one has purchased a subsciption for a license of Creo, you should have some sort of info about it.
When you've received verification e-mails or whatever indicating that all is good with the licensing, keep the various numbers and account info they provided you handy.
You have to download the Creo Software. I get my downloads directly from PTC at the following URL. Your URL may differ if you're in a different country, etc.
https://www.ptc.com/en/support
Once you've downloaded the software, which is in a ZIP file format, the installation software programs are included in there. A typical listing (this one is for Creo 9.0.9.0) looks like this:
Creo Zip File Contents
To install the license server you need to run "install_license_server.exe". Do this first.
Once your license server is running, use the "setup.exe" program to install Creo.
If you have already got Creo running and just need to update the license to the latest, that's another story.
Here are some instructions I put together for updating the license file. We have to do this every year because licenses are all subscription based.
go to following pages.
https://www.ptc.com/en/success-paths/get-started-creo-parametric/setup/download-install-software
https://www.ptc.com/en/support/creo-landing
Info:
Open your license file in notepad and search for following lines
#START: License File for HOST ID .....
If the following 2 lines are below these lines, then you have a floating license.
SERVER __HOSTNAME__ PTC_HOSTID=..... 7788
DAEMON ptc_d __PTCD_PATH__
If these 2 lines do not exist then you have locked license.
Henry
