How to remove spaces from "Creo 2.0" and "Common Files" folder in Creo 2.0 installation directory path using silent installation
MartinHanak
see attachment
Martin Hanák
2 REPLIES 2
Here's the link to the original KB article
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS101303
jkent
(To:MartinHanak)
We just modify the xml files in the pim/xml folder of the CD. That way your first install is correct and you don't have to go back and redo it.
