"Perez Edgar" wrote:
hello everybody. I can actually add new folders to COMMON FOLDERS, by RMB>add to common folders. The issue is that whenever i exit PROe, and start it again, the folders i previouslly added are not there. Another thing that i notice is that some changes are being done by proe itself in the starting folder (i mean, the folder we indicate by RMB in the properties of the proe icon or access). Some folders with weird names appears on that folder... .fld, ings, n@, etc. I try to delete those folders, but they are being created again after i open proe back. I think its something related to tha problem mentioned above. Thank you very much!
"Joe Varghese" wrote:
try starting proe directly from the proe.exe, which exists in <Loadpoint>\bin.
anonymous wrote:
Try renaming the file "config.sup" & "config.pro" to something else.
try raising a log a to PTC. They should help you then.
welcome Also, post it when you get it solved.. I too had similar issues.
