I changed my network card and now I can't move my licence
ptardy
7-Bedrock
Hi Martin,
I managed to fix it myself. I found that I had 2 problems:
- The license file did have the SERVER and DAEMON lines, but were not customized for the PC I was working on.
- The FlexNet server was not running properly and giving error messages when I made queries about the license status.
After I fiddle with both issues, the license did end up working.
As for question 2, I'm running CREO 3.0 Parametric and it seems to work fine.
11 REPLIES 11
TomU
(To:ptardy)
Licenses are tied to the MAC address.  You will need to log on to PTC's license support website and request a license move from the old hardware to the new hardware.  It's pretty quick and completely automated.
TomD.inPDX
(To:ptardy)
You need to contact PTC to have your license file updated.  This is a process but it shouldn't require an active maintenance.
...yes, what Tom said
Already done, but when I want to setup the  licence, (with the TXT file I received from them, the status is Starting.... And nothing
MartinHanak
(To:ptardy)
if you use lmadmin license manager installed in C:\Program Files\PTC\FLEXnet Admin License Server directory then:
  • find license.dat file (maybe in licensing subdirectory)
  • make copy of license.dat file
  • open license.dat file and TXT file with new license
  • in TXT file in SERVER line replace __HOSTNAME__ with your computer name (you can copy it from license.dat file)
  • in TXT file replace DAEMON line with DAEMON line from license.dat file
  • delete the whole contents of license.dat file
  • copy the whole contents of modified TXT file into license.dat file
  • save license.dat file
  • close TXT file without saving
  • start/stop lmadmin service
Martin Hanak
Martin Hanák
Ok!
There is not folder on (C:\Program Files\PTC\FLEXnet Admin License Serve) But into my Services.msc I have FLEXnet Licencing Service (started) (I checked on C:\Program Files (x86) and nothing)
Where can I find this Program ? ''Flexnet''
ptardy
7-Bedrock
(To:ptardy)
Hi Martin Hanak I change the (licence.dat) following your steps (mine, is licence.txt it'S normal ? ) and Finally I Installed the software, but I have this message when I open it
If I say Ok the software is closed
MartinHanak
(To:ptardy)
Pierre,
we have to start from the very beginning ...
Question no.1: Does your license file (received from PTC) contain SERVER and DAEMON lines ?
Example related to my notebook:
SERVER hpmh PTC_HOSTID=1C-C1-DE-BA-30-44 7788
DAEMON ptc_d D:\PTC\flexnet\x86e_win64\obj\ptc_d.exe D:\PTC\flexnet\licensing\ptc.opt port=7789
Question no.2: Your picture contains information about PROE_FoundationAdv and Mechanism_Design (Version=32.0). This means that the license enables you to run PTC software up to Creo Parametric 1.0. What software version do you use ?
Martin Hanak
Martin Hanák
Hi Martin,
MartinHanak
(To:ptardy)
Congratulations !
Martin Hanák
Mahesh_Sharma
22-Sapphire I
(To:ptardy)
You may mark appropriate replay in post as correct answer.
