I was modifying the creo_parametric_admin_customization.ui in Creo 10. This .ui file gets put in the users loadpoint via our Creo startup scripts. I didn't realize that the .ui file contained the windows scale.
We can restore the old .ui file, but I would like the .ui file to not contain anything but the ribbon customizations. Is there a way to do that?
Ok, I got it fixed. I used my startup that just loads one ribbon from the start in directory. I always verify this by picking File, Help, system information, system information, and scrolling down to the section showing the configuration files loaded. It should only show one .ui file loaded with no path in front of it.
With that assured, I edited the ribbon and added some additional commands to the new tab I was working on. After picking ok I grabbed the new .ui file in my start in directory and placed it where my old one was that had the windows_scale set to .5.
Using the new .ui file the normal startup opens maximized.
I find it disconcerting that editing the ribbon is saving all kinds of other settings like the window size instead of just the ribbon modifications I thought I was making.
