I need to reconfigure an installation of Creo 8.0.8.0 to include Generative Design
LF_9964242
3-Newcomer
I am using Creo Parametric Release 8.0 and Datecode8.0.8.0
I was hoping to understand what Application Feature would be required for Generative Design. We have a user who has a very basic install and it is missing.
@LF_9964242 wrote:
Thank you very much for your response. That is good to know that it would be better to do a reinstall, I will do so. The user does have a compatible machine and an applicable license
When I am reinstalling the application would I have to pick a particular feature? Or is this included by default? I think someone unchecked several boxes in the install as this is included in our other builds.
unfortunately I don't know all the installers by heart. When installing, proceed slowly and read all the information carefully.
Edit: Check the configuration of startup command.
Martin Hanák
3 REPLIES 3
1.]
User must have license containing Generative Topology Optimization module.
https://www.ptc.com/en/support/article/CS323850
2.]
User must have computer with supported graphics to perform Generative Design.
https://www.ptc.com/en/support/article/CS352348
3.]
To "reconfigure" install I suggest you to uninstall it and do new clean installation.
Martin Hanák
Martin Hanák
