I want to create a chinese_simply interface in creo
yhuang-2
11-Garnet
I want to create a chinese-simplified interface in creo.
I use the chinese-traditional win7 and I want to create chinese-simplified and chinese-traditional interface in creo.
Below the picture
But I open the chinese-simplified interface which is englihs interface.
When I install Creo 3.0 m090 , I Add the chinese-simplified langurage package which is not working.
And I add the ENV=Lang=chs in the chs.psf which is still not working
When I select chs and open the creo, It's still English Interface.
I don't know why can I open the Creo 3.0 m090 that is still English
Below the picture ( chs.psf  & install)
Could anyone help me ?
Thnak you
try ENV=PRO_LANG=chs
According to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS110907, you license must contain Chinese_translation license and this license must be included in ​psf​ file.
MH
Martin Hanák
MH
Martin Hanák
Hi , Martin
Thak you for your reply
My croe 3.0 m090 is ok that is chinese-simplified interface.
Thank you very much
yellow
