IF ELSE relations causing model check errors
Participant
I have entered the following relation and get model check error stating that I have multiple relation assignments. Is there anything wrong with how I have written this or is their a better way of acomplishing this?
Thanks!
Jason
My relation:
MATERIAL = MATERIAL_PARAM("condition")
If material=="A"
description_line2=material + " (SEE NOTES)"
Else
If material=="B"
Else
If material=="C"
Else
If material=="D"
Else
Endif
Endif
Endif
Endif
Here is what model check is returning:
RELATION_MULTNumber of multiple assignments in the relation file:13Ifmaterial description_line2 Else Ifmaterial description_line2 Else Ifmaterial description_line2 Else description_line2 Endif Endif Endif
SUMMARY: IF ELSE relations causing model check errors
Problem solved!! Twice!
Solution 1:
This sounds like one I ran into at one time. If I remember correctly, ModelCHECK has difficulty with the mixed case on the "If" in your relation. Try changing the word "If" in yourrelation to be all lower (if)or all upper (IF)case and see if the problem goes away. I would also do the same for the "Else" and "Endif" statements as well. I opened a call when I discovered this and PTC opened an SPR. I don't recall when it was going to be corrected, but I want to say it was in Wildfire 5.
Ron
Solution 2:
I would try just using the OR pipe (|) in your conditional instead of mutiple conditions:
If material=="A" | materal == “B” | materal == “C” | materal == “D”
Else
Endif
Eric
Thank you Ron and Eric.
Jason
Original post:
Original post:Dec 12, 2008 11:06 AM
Thanks!
Jason
My relation:
If material=="A"
Else
If material=="B"
Else
If material=="C"
Else
If material=="D"
Else
Endif
Endif
Endif
Endif
