IFX teaching materials
mmello
Hello I'm from Brazil. Please do you have any IFX material for Parametric Creo 7? I have a course coming up and PTC doesn't have any e-learning material.
Thanks!
Translated by the Community Moderation using Google Translate
Olá, sou do Brasil. Por favor, você tem algum material IFX para Creo paramétrico 7? Tenho um curso a chegar e a PTC não tem material de e-learning.
Obrigado!
VladimirN
(To:mmello)
VladimirN
(To:mmello)
"[Knowledge Hub] Creo Parametric - Intelligent Fastener Extension (IFX)": https://www.ptc.com/en/support/article/CS180439
mmello
(To:VladimirN)
Thank you very much for your reply... it did help!!! Would you also have any material on metal structures? I know students will ask about creating structures... I wonder if there is anything about that? Thanks for your help!
VladimirN
(To:mmello)
... just note ... Framework = AFX not IFX
Martin Hanák
mmello
(To:VladimirN)
Hi Vladimir.
Thank you very much for your help! What a nice piece of material... I'll look at it carefully!!! It really helped. Cheers!
