Hello I'm from Brazil. Please do you have any IFX material for Parametric Creo 7? I have a course coming up and PTC doesn't have any e-learning material.
Thanks!
Translated by the Community Moderation using Google Translate
Olá, sou do Brasil. Por favor, você tem algum material IFX para Creo paramétrico 7? Tenho um curso a chegar e a PTC não tem material de e-learning.
Obrigado!
"[Knowledge Hub] Creo Parametric - Intelligent Fastener Extension (IFX)": https://www.ptc.com/en/support/article/CS180439
Thank you very much for your reply... it did help!!! Would you also have any material on metal structures? I know students will ask about creating structures... I wonder if there is anything about that? Thanks for your help!
Take a look this one: https://www.youtube.com/playlist?list=PLVY1MWAL56QBtQ6xAUb_TnvF6OfGHO2OK
... just note ... Framework = AFX not IFX
Hi Vladimir.
Thank you very much for your help! What a nice piece of material... I'll look at it carefully!!! It really helped. Cheers!
