Okay...maybe I is just stoopid... But...
I want to display the curvature map ofmy style feature curves but the stinkin option is grayed out in the Customize Screen menu!I can get the Analysis curvature to work...but that does not help. Analysis features are not real time. Is there a config option I need to switch. The client is running WF2.
What gives?
To all that have responded so far...
I am in the style feature and module. The curvature display and the curvature hide are the only two things grayed out in Customize Screen.
In Reply to Doug Schaefer:
You may have to be working in a style feature to get to those icons.
Doug Schaefer
Yep...I am as well. I can't understand using a styling / surfaceapplication without the ability to see the curvature map in real time.
does anyone know if this was a bug in WF2? It makes zero sense!
