Hi everyone,
I'm wondering if any of you came across a situation where the import data doctor functionality was suddenly lost.
I am used to accessing the import data doctor application when editing the definition an imported geometry feature. Now I can't do it because the "1st-aid kit" icon is grayed out.
I checked the license list, and the one for Import_Data_Doctor is there, so I'm not sure what's going on...
Seems to be license related only. Still create a step file from Creo, import that and check if IDD is still inactive.
Check IDD license available in session under File > Help > System information > Configured Optional modules.
Also, check when editing the import feature, dynamic preview is "No Preview" or "Un-attached". If it is No Preview, IDD will be inactive as in attached image.
Also check, value of config option dynamic_preview.
That's the one, I recently changed dynamic_preview to NO in order to deal with some geometry-intensive models.
