The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Importing .dwg or .dxf
ptc-2819933
1-Newbie
I am having issues when importing a .dwg or .dxf into CoCreate 2008. The drawing loads fine and looks ok, but it is scaled down to 2/3 from the original. (i.e. a 10.00 edge measures 6.67). I have the unit settings correct, but I can't find anything that might be the cause of this. I am new to CoCreate, so it may be simpler than I am making it. Any ideas? Thanks in advance!
2 REPLIES 2
Maybe an inch vs. mm conversion issue? The following discussions might be related:
[*:562cdc03cf] http://cocreateusers.org/forum/showthread.php?t=6681 [*:562cdc03cf] http://cocreateusers.org/forum/showthread.php?t=4761 [*:562cdc03cf] http://apps.cocreate.com/OneSpaceModelingPE/Secure/Forum/forums/thread-view.asp?tid=422
Hope this helps, Claus [/list]
