Inadvertant dragging and dropping
Dale_Rosema
Is there a way to lock the structure of the model tree so that you can't inadvertantly drag and drop a part from one place to another, wait for it to regenerate, then drag it back, and re-wait for it to regenerate.
Or can you set the config file such that it asks you and you click - Yes I would like to move this part in the model tree.
Dale
2 REPLIES 2
Dale_Rosema
(To:Dale_Rosema)
This typically happens when I left click on a component to select it in order to right click on it and edit, edit definitions, .....
Dale_Rosema
(To:Dale_Rosema)
A product idea that can be voted up describing what I was experiencing.
https://community.ptc.com/t5/Creo-Ideas/Stop-Model-Tree-Reorder-Becoming-a-Restructure/idi-p/467294
