We are using Creo 1.0 M030 and we have experienced this since WF5. The loading times for models and drawings becomes a huge factor in my efficiency because I spent so much time waiting. Even switching between drawing sheets can take quite a while. My computer has a SSD, i7 processor with 8gb RAM. Win7 x64 and a quadro 3000M. I am using a Dell M6600 laptop. Are there any settings to increase performance of drawings or something that I can do to help with this?
I suspect it is the processor speed. At only 2.4Ghz, these machines are not exacly blazing. I have the same setup except the HD is a normal platter drive. I believe you can upgrade the CPU for a faster one but not by a while lot. Contact Dell to learn more.
If you go this route, please report back your findings. I am also interested in doing this for the same reason.
Aaron,
open Task Manager and look at Performance tab (CPU Usage) during loading of your model/drawing. Make sum of CPU usage of all threads and you will get CPU load. If the sum is ~100% then the CPU is a bottleneck. If not then the problem is somewhere else.
Martin Hanak
I have attached an imagine while using the drawing. I will have to wait about 2 minutes for the page to load if I switch pages (load times dependent on the page I switch to) or if I activate another window and then reactivate the drawing window. The CPU never reaches more than 18% and cores 4,6,7 never show any activity. My boss also has the same type of computer and experiences the exact same thing so it is not something about my computer. Would submiting a ticket solve anything?
Aaron,
13 % is an average CPU load.
8 * 13 = 104 % CPU usage. So it seems to me that CPU could be a bottleneck.
You can try the following:
>>> in Task Manager activate Processes tab
>>> select xtop.exe process, press right mouse button and click Set Affinity command
>>> now you can see the list of CPU cores assigned to xtop.exe
>>> check CPU 0 and uncheck all others
>>> load your model/drawing ... xtop.exe will use only first core and you will see the real load percentage for "1 CPU computer"
>>> you can use Set Affinity command again and test another combination of CPU cores
Martin Hanak
Aaron,
in the past I met such behaviour, when I tested complex drawing containing 5 sheets and 100 views on them.
Martin Hanak
If you use a datecode of Creo 2.0 older than M110, you might want to try M110 or even better M120, as a lot of performance optimizations in handling drawings of large assemblies have been added.
Otherwise we recommended using the MyFilter functionality and remove model geometry from the filter used while working with the drawing.
This is because most of the slowdowns in Creo are related to pre-collecting annotations and geometries for pre-highlighting.
One of the main factors was that the default filter has changed from "Drawing Items and Views" to "General".
Disabling pre-highlighting (not always applicable) or clever filtering normally improve performance.
Martin,
It appears that you are correct, if I use a single core it stays maxed at 100%. So the only way to increase the model load times is to upgrade to a faster CPU? Making the models smaller really isnt an option.
Aaron,
it is difficult to give you a valuable advice ...
If you can >>> test PC with faster CPU, but I am not sure that an improvement will be worth of spent money. Maybe overclocked desktop PC will provide more power ...
It looks like the problem is related to drawings. My suggestions follow:
1.] do not use multisheet drawings
2.] when you are working on drawing - use selection filters (see bottom right corner of window)
3.] when you are working on drawing - use Erase command to "suppress" unimportant views temporarily
Good luck
Martin Hanak
The available tech for laptops is quite limited. If you really need a faster computer for certain operations, it might be worth going back to the desktop brick with more power. Desktops have much higher CPU speed available than their laptop brothers. If you are using a license server, this may not be too big an issue.
I think the calculation above is incorrect. I ran a benchmarking program my computer and took a screenshot of the CPUs.And by the logic above I am running at 750% of the CPU usage... Any reason why Creo refuses to use more than one core? I needed to add something to the top level assembly and it took about 15 minutes to put 3 contrstaints in because of the constant waiting.
Aaron,
your benchmark is probably multithreaded, i.e. it is able to use all CPU cores. Unfortunatelly most of ProE operations are SINGLE threaded.
Also it looks like your assembly is the special one ... I think nobody is able to explain why you have problems with it. Only you can investigate your own data
Martin Hanak
This particular computer is simply a dog with Creo. The best you can do is tame down the graphics requirements. Turn off textures; use pure wireframe; reduce all the graphics quality settings in the environment. When Creo 2.0 M030 came out, I lost even more performance and it all had to do with graphics.
If you only use your machine for Creo Parametric, then I recommend to turn off multithreading in BIOS.
With that you will get more power from each of your single cores when used separately.
Also if you can add some additional cooling to your processor then it could be worth it to try intel turboboost.
That way you should be able to get max out of your intel processor.
More system ram helps, I see your free ram is down to the last 5mb. chuck some serious graphics performance at it, Quadro k4000 should help. The more cores you have on graphics the better for Creo 1.0.m040. On multi page drawings I was down to 1 mouse click selection per couple of minutes, until I got things powerful enough to run what I have to do. I have 16GB ram and the k4000 and am running family table assemblies, open size of around 20gb, now with not a lot of waiting around.
Loading of drawings is usually slow because it's re-rendering your drawing views. As stated above it's really irritating that HLR is so tedious and also really irritating that each view isn't rendered via a seperate core. However it is a reality even in Creo 2 and 3 i think.
Recently demoed to a user bitching about the same observation here, shaded with edges view 6seconds, HLR view 6 minutes. He started using drawing reps, forcing wireframe config, setting views to use environment very quickly and now just lets the view rendering be the last bit of his process.
Hope it helps, hope i understood the pain properly.
Of course performance is always relative and equally always sux. Some of our users insist on modelling threads and still complain that HLR takes forever.
It's not just performing HLR, it is creating records representing all the real and silhouette edges, both completely visible and partially occluded.
Identifying the edges could be done on separate cores, but each core is competing for access to the same in-memory database to keep the edge list current. It probably could be done, but writing parallel applications is easiest when there is little interaction, such as ray tracing where each pixel color is independently arrived at.
On the way to slowdom - I've had users import shrink wraps of the top assemblies into sub-assemblies to make installation drawings, with same sub-assemblies going into the assembly the shrink wrap came from. Query select an item and it turned out there were 2-4 copies of the top assembly surface geometry in the top level. If it's blanked it ceases to exist, right?
A lot of time can be saved, and performance gained, by going through the message log and getting rid of the causes of the errors that pop up. ![]()
Francis comment is a good point. If you were to inspect the timestamps in the trail file on reteive, you'd be able to see how much of the wait is HLR related (and yes the other stuff that David pointed out) and how much is pure retreival. If you're seeing msgs relating to ambiguous sketches, regenerations of instances, circular references it can impact you quite a bit for sure. we've seen 15% improvements on retreival just by cleaning up models for sure. I'm thinking of writing a small script to parse the various text logs that get chucked out by creo to make a condensed list of complaints. Half way there, if anyone has a finished one they'd be willing to give me i'd appreciate it.
Creo can be so messy with disgarded stuff that has failed behind the scenes, failed references to parts no longer there, suppressed features that are no longer there in the models and assemblies can be difficult to detect and delete. I have had family table vairifications take 8 hours to do. Since these have been got on top of bigger vairifications now take 30 to 40 minutes to complete.
I have observed huge performance improvement after setting below properties for swtich from one drawing sheet to another sheet in multisheet drawing.
Intially it was taking 1 to 2 min time and now it taking less than 4 sec.
1. Set config.pro option ‘show_axes_by_view_scope’ to ‘top_model_only’
2. Open drawing
3. Set drawing detail option ‘user_command’ to ‘delete_erased_axes’
4. Update Sheets and save the drawing
Yes, this is explained in the knowledge database article CS27735 : Switching to Annotate tab in drawing mode takes exceptionally longer time in Creo Parametric than in previous releases
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS27735
But this seemed a little off-topic, as the thread was originally about "long load times".
However, if this thread has mutated into general performance issues with Creo Parametric, then you may want to check this new hub article as well:
CS188291 : Slow performance in drawings with Creo Parametric in general or in comparison to older versions
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS188291
I am very surprised no one has mentioned to turn on Fast HLR. View tab in drawing second icon to the left. This is also a config.pro option. This option drastically speeds up HLR performance during initial retrieval and switching sheets. Also CREO 4 brings multi cores to bear for HLR removal FINALLY !
Fast HLR causes other issues. Due to a behavior change with Creo 3 we have to leave it administratively disabled.
Tom with out Fast HLR I could not do my job. The issues you sent in my opinion are small and none of them have affected me to date.
The no display of threads in drawings was a show stopper for us.
Tom agreed but when we create PDF's with threads in drawings, they show up do they not for you ?
I haven't checked. We tend to print directly from Creo.
