I am using Creo Parametric 8.0 8.0.1.0
Installation Assistant for Creo 8.0.1.0 (setup.exe) won't run on Windows 10 Build 21H1. The error is " This app can't run on your PC - to find a version for your PC, check with the software publisher"
Here are the errors that I faced
It ran normally on previous versions of Windows 10.
Try the solution from this article - "This app can't run on your PC - to find a version for your PC, check with the software publisher": https://www.ptc.com/en/support/article/CS332423
