Installation FloEFD for CFD analysis?
akaramyan
Hello everyone, I wonder to know how to install FloEFD in creo parametric for CFD analysis?
Just install FloEFD (for Creo) after installing Creo Parametric.  It will create new start-menu items that run Creo with a different "start in" directory (containing the config files that FloEFD needs).
Once Creo is run that way, just open an assembly and you'll see the "Flow Analysis" tab in the ribbon.
-Doug
I have already done what you say, but I need config for <<Options>> -------<<Configuration Editor>>
For example if I want to add <<Framework>> for construction work I add in <<Configuration Editor>> , afx_enabled_yes.
And what exactely is your problem?
Did you ever get this to work....?
