Hi apologies in advance if there is already a post regarding this but I couldn't find one specific enough
I attempted to install ProE 5 (education edition) on my HP windows 7 desktop, I get as far as clicking "setup.exe" and it asking my permission for program to make changes to computer, click yes but nothing happens
I read that ProE 5 does work with Windows7 64bit, although I am pretty new to this is likely there is something i'm missing
Gregor,
use 64-bit installation media to install ProE WF5 64-bit on W7 64-bit. If you want to install ProE WF5 32-bit then look at http://communities.ptc.com/message/162442#162442
Martin Hanak
Gregor,
Martin Hanak
Thanks very much, discovered I was using 32bit installation software and acquired 64bit which is available, thanks again
