I accidentally installed the wrong size 64 bit instead of 32 bit version , how can i re-install to the right version without affecting my free student version license.
Hello.
You have to uninstall a bad installation and install the correct version of Creo Elements/Pro 5.0 (formerly Pro/ENGINEER).
This is the only way to fix it ![]()
Vladimir
Hello.
Vladimir
