Installed the Creo3.0, choose the Chinese ,but it display English,
Who can tell me why?What should I do Let it display chinese,thank you!
see Re: Change Language in Creo 3.0
Chinese Simplified
ENV=PRO_LANG=chs
Chinese Traditional
ENV=PRO_LANG=cht
Also your license must contain Chinese_translation module (code 155)
MH
thank you first
I read the license
Yes,my license contains Chinese_translation module (code 155),
But where should I find the
Chinese Simplified
ENV=PRO_LANG=chs
Chinese Traditional
ENV=PRO_LANG=cht
If you want to set specific language, then you have to go to ...\Parametric\bin directory and edit parametric.psf in Notepad.
Add following line at the end of the file, if you want to set chs language:
ENV=PRO_LANG=chs
MH
Jun,
Does the reply from Martin answer your query? If that resolved your query, mark that as correct answer.
