Installing Creo 3.0 problems
djeffers-3
     I am on a ftc team and I am trying to download creo. I found where to download it, and i downloaded it. But it would not extract the setup file. I have an hp windows 10 computer. What do i do?
6 REPLIES 6
please answer 2 questions.
1.] what is size of downloaded zip file ?
2.] what software did you use to unzip downloaded file ?
MH
Martin Hanák
well its called MED-100WIN-CD-400_M070_Win64
and im not sure what u mean by what software i used to unzip the file
BenLoosli
(To:djeffers-3)
Did you use WinZip or some other program to unzip the files?
Did you open the compressed folder and copy the files to another directory?
Did you open the compressed folder and just run the Setup program?
The first 2 should allow you to run the Setup program when the files have been uncompressed.
The last item will not work.
ok, i did the third option, so how do i accomplish the first or second?
BenLoosli
(To:djeffers-3)
I find it easiest to just open the zip file and then open another empty folder and drag and drop the zip file contents to the empty folder.
No need to download anything other than the PTC zip file.
There is my zipped files from the PTC download.
This is the zipped file contents after opening it.
Empty folder to copy the files to.
Just drag all the files from the opened zip folder to the empty install folder.
Then run setup.exe from that folder.
if you display properties of downloaded file, you will see its full name .... MED-100WIN-CD-400_M070_Win64.zip. You have to unpack this file to get copy of installation DVD. I use 7-zip 9.20 program for this purpose ... download and install appropriate version from http://7-zip.org/download.html page and extract MED-100WIN-CD-400_M070_Win64.zip file into MED-100WIN-CD-400_M070_Win64 sub-directory. You will find setup.exe in MED-100WIN-CD-400_M070_Win64 sub-directory
MH
Martin Hanák
