Installing Creo3 under Windows 11
Dom_CHENTRE
Hello, I currently have a subscription for CREO (8-11) that will end at the end of the year.
For financial reasons I will stop it.
I have an old Creo3 license that is permanent. Will it work on Windows 11?
When I will no longer have maintenance, will I be able to change my host ID?
For this Creo3 that is no longer under maintenance.
Thank you
10 REPLIES 10
1.]
PTC still enables to move old non-active Creo 3.0 license from old HOST-ID to new HOST-ID for free.
2.]
If old non-active Creo 3.0 license is floating one then you can install current FLEXnet version on Windows 11 machine and "put Creo 3.0 license into it".
3.]
I don't know if the setup.exe from the Creo 3.0 installation media will work on Windows 11. If that doesn't work, the Creo 3.0 installation can be copied from the old computer.
Martin Hanák
Dom_CHENTRE
(To:MartinHanak)
Hi, thanks a lot !
Yes, Creo3 is permanent and floating.
For point 3.],
You means that I can copy installed files from an old computer ?
No registry settings, environment variables, and so no ?
Or just copying ISO content ?
BenLoosli
(To:Dom_CHENTRE)
Creo does not use the registry, so you can just copy the installation from computer A to computer B.
You will need a new license, unless you have a floating license and it runs on a server.
I do this with my single network installation. Install is on a Windchill server, then copy the Creo loadpoint to a network drive and change a few settings in the b.bat and .psf files and the config.pro and we are good to go with a new version.
@Dom_CHENTRE wrote:
Hi, thanks a lot !
For point 3.],
BenLoosli already answered your question on ‎2024-10-14 08:14 PM.
Martin Hanák
Dale_Rosema
(To:Dom_CHENTRE)
Remember that Creo is not reverse compatible. Anything worked on with a newer version of Creo will not be able to be opened with Creo 3.
Dom_CHENTRE
(To:Dale_Rosema)
Yes I know, thanks.
But my old company projects are still on Creo 2 🙄
So in the future, new projects will be done with Creo3.
Dale_Rosema
(To:Dom_CHENTRE)
You mentioned:
So that is what I commenting on.
Dom_CHENTRE
(To:Dale_Rosema)
thanks, but my fear is what will happen when I no longer have the subscription and return to Creo3 (permanent, floating).
Still access to change PC, and still access to the community.
StephenW
(To:Dom_CHENTRE)
The community is completely open with the exception of the "ideas" area.  You have to have a certain level of maintenance to submit and kudo ideas.
termination of subscription means that you will lose access to the installation media download area.
You will be able to move Creo 3 license from "old" PC to "new" one.
You will be able to access Community.
Martin Hanák
