Installing Mechanica question - SUMMARY
Highlighted
And the winner is... Doug from Atrus Inc.
It was actually pretty simple. I knew it had to be. Here's how:
Run ptcsetup.bat in your ProE/bin directory. Then forward to the screen
called Optional Configuration Steps. On this screen check mark the
Configure Other Product Interoperability option, then click next. This will
put you on the screen in the attached image. Look towards the bottom to
find the Mechanica installation pointer. Use the folder to browse to your
Mech installation directory and when your done, select Configure and you
should be all set.
See attached image.
<<product interoperability.jpg=">>
Original question:
How do I make Mechanica run from within Pro/E?
Happy Friday everyone.
Bob
